ratcheting: The loading results in only primary stresses without any cyclic secondary stress
YuJie_PV
CN
hi all experts,
i am reading part 5 of ASME VIII-2, and find such sentence in paragraph 5.5.1.6:
Protection against ratcheting is satisfied if one of the following three conditions is met:
(a) The loading results in only primary stresses without any cyclic secondary stresses.
i've thought that i am familiar with the rules in Part 5 until now. i am confused with the clause. Through my work experience of so many years, i've never seen the clause is used in the FEA report. it doesn't make sense. the clause seems an easy and simple way for ratcheting analysis, but nobody use it. the manufacturer always tends to minimize their burden of FEA if possible.
i am quite curious under what kind of loading, would result in "only primary stresses without any cyclic secondary stresses"? only internal pressure?
thanks in advance.
Refer to Table 5.6. Any of those scenarios that lead to a Pm classification are primary stresses and are satisfied for the ratcheting criteria.
cbPVme, thanks.
i know table 5.6, according to which secondary stress takes place in so many locations of a typical pressure vessel, hence i doubt no pressure vessel really falls into the scope of 5.5.1.6 (a). is there any specific vessel really fitting for the article?
Thanks so much.
Practically, I don't think there is any vessel that is free of secondary stresses. Even a sphere needs a nozzle to function which creates a discontinuity effect.
I think the intent of the code is that each location is being assessed independently. Hoop stress in a cylinder contains only primary membrane stress and therefore, that specific location will not ratchet. Other areas in the vessel when assessed will have secondary stresses and will need to be fully evaluated for ratcheting.
