Syahar1975
Dear experts,
Is there any code states that if on the vertical joint of the shell plate on the same location there are more then 2 times repair, so that vertical joint shall be cut out.
I have an assumption that many repair on the same location will make that location is brittle due to many heat input during repair. This may be the reason behind.
Syah
Syah
