Greetings and thanks for reading my message,
I am modeling a two story building in SAP2000, this building has frames spanning 18m so the beams are trusses. My question is how should i model the connection between truss chords and frame columns.. currently i set the connections not to transmit moments, only shear and axial force... this causes a pair of forces in the columns that generate a bending moment; however i am not sure if this is the expected behavior of trussed beams supporting gravity loads. Reading structure books and examples trusses are always modeled as being simply supported, but to obtain a similar behavior in my structure i would have to release the axial transfer of forces between column and truss. I am at a loss here.. thanks.
