Theoretical Question - Planar Truss Problem 5
comhedoisl
Hi all.
This is an interesting theoretical question from a book of Feodosiev - Advanced Stress and Stability Analysis. It reads like this:
"A plane truss consisting of n>2 equal and equally spaced rods, connected in a common node, O.
The force P acts in the plane of the truss.
Show that the displacement of the node O is always directed along the force P and that the value of this displacement does not depend on the angle /alpha."
The book does provide an answer to this problem, but not with enough detail -- at least from my point of view. I'd like to have a more detailed discussion on this problem with other folks. Could you help me providing your insights?
**the blue circle is not part of the structure
Thanks.
OK, I think that makes sense. It's clearer now for me.
Thank you, Tomfh.
Using deformation compatibility?
Hi Nick. That may help answer the displacement aligned with force bit. I’m not sure how to do it with more than 3 rods, even with 3 may be difficult, I havent tried yet.
But the “displacement value independent of angle” bit would still be pending if using only displacement compatibility.
Thanks.
We have a structure resisting a single applied load; that load can be represented by a vector in the form P = ai+bj+ck. That expression provides both magnitude and direction of the load P.
It seems to me that the resultant of all of the reactions must be equal and opposite to the applied force. Putting that another way, it seems to me that R+P = 0, where R is the vector sum of all reactions. If that is true, then the statement in the text book mentioned in the first post is correct. It would be true for the regular wheel configuration shown in the OP and it should be true for any alternative stable configuration.
...a single applied load; that load can be represented by a vector in the form P = ai+bj+ck.
There is a small problem.. The OP 's question is for 2 D ( plane truss consisting of n>2 equal and equally spaced rods, making a circle ,connected in a common node, O. ).
For the 3D load, the truss shall be 3D and the rods shall be equally spaced in a sphere.
A plane truss
That simply means that the k term is zero for both P and R. What I said before is still true.
They are 2D vectors of the form P = ai+bj and the vector sum P+R = 0.
Today, I checked with my developed FEA program for trusses with 4 symmetrical elements. The given postulates hold good in the sense that:
1. The magnitude of displacement does not vary with the direction of the applied force.
2. The displacements are along the direction of the applied force.
Of course 1. and 2. would be true. But not as a result of elements being symmetrical. The given postulates hold true for any stable arrangement of spokes, whether symmetrical or unsymmetrical, whether odd or even in number.
Every spoke is pin connected at both ends, but the central pin, starts to move as soon as force "P" is applied. The direction of the applied force must be held constant, relative to global coordinates, not relative to spoke positions, because each spoke is moving to stay connected at the center pin.
No… as I posted previously, considering an example of 3 equal rods, but not equally spaced, the displacement of node O (common node) does not align with the direction of the force.
Yes, I think that should be assumed, as it’s not stated in the question.
That structure was indeterminate. You did not analyze it as an indeterminate structure. Your sketch shows that Members 1, 2 and 3 rotated after loading; and that changes the reactions. After loading, P should be at Node "O" in its final position, not its original unloaded position.
Equilibrium requires that the vector sum of resultant forces must be equal and opposite to the applied force. How could it be otherwise?
If P = ai + bj, then clearly R = -ai - bj, which mean that P + R = 0.
This would be second order analysis... Although it is not stated in the question, we may assume a linear elastic analysis, not considering second order (P following node in deformed configuration*).
*Assuming linear elastic analysis and displacements small enough that there's no significant difference in the reaction forces between original and deformed configuration.
The structure was analyzed as an indeterminate structure. The bars are hinged at each end, so they will deform and rotate accordingly, for compatibility.
It can not be otherwise, this is true. But it does not follow from equilibrium (alone) that: (1) the displacement of the node should be in the direction of the load, and (2) the displacement magnitude of the node is not dependent of angle /alpha.
Just had another look at your diagram. Member 3 has 2.4 kN compression downward. Member 1 has a vertical component of 2.4 kN upward. This suggests that your diagram is out of scale. There is no reason for Node "O" to move up or down. If it does not move up or down, then it simply moves to the left, which confirms that displacement of Node "O" is horizontal, which is parallel to the applied force P.
There’s a reason for Node “O” to move up, and that would be compatibility.
Each member deforms (Fi)*L/EA, Fi being the axial force in each member.
Using the values from the example:
F1 = 4 kN (compression)
F2 = 6.8 kN (tension)
F3 = 2.4 kN (compression)
So, deformation of each member will be different. When deformed, members 1 and 3 will be shorter, and member 2 longer, all in different amounts.
We need compatibility, so the members will rotate some amount.
I suggest you check it using an appropriate software package. I don't have one myself, but I believe goutam-freela does. If not, someone else will certainly have one. Failing that, it can be checked by hand calculation.
Thanks for running some cases, Retrograde.
Symmetry is key here... But it’s not that trivial as it seems to be.
I think the reasoning brought by JStephen and Tomfh is one path to solve the exercise, if you apply it to the symmetry of “stiffness distribution”.
After saying that, I wonder if that would show on the “global stiffness matrix”…
Maybe for the type of truss of the exercise (equal rods equally spaced, sharing a common node), the global stiffness matrix is always symmetrical? Or always proportional to identity matrix?
I’ll try investigate that
I also ran my software for asymmetrically arranged truss. The result is given below: One can see that both the above postulates do not hold good for this case.
The explanation is as follows:
Suppose P is applied in +ve x direction.
1. There will be tensile force along asymmetrical member(end co-ordinate(-.707,-0.707)) as this will try to extend.
2. This tensile force will have a vertical component, which will be neutralized by tensile and compressive forces along vertical members.
3. There will be vertical movement of O due to 2 above.
4. So applying P along x direction results in displacement in y direction also.
5. So displacement is not in the direction of P.
The axial forces from the output are given below for P =1000 along the x-direction:
F= -714.2611(horiz. memb. along +x), -142.8695(vert. memb. along -y), 404.0959 (asymmetric) 142.8695(vert. memb. along +y)
