We have a new ASME Section I boiler under construction and have found an issue with the Secondary Superheater Outlet Header. One of the top support lugs was installed in the wrong location. The superheater header is a P5B material, 1.5" thick, 18" ID and was PWHT'd at header fabrication. We'd like to weld a new support lug/pad to the top of the header shell, at the correct location. The attachment fillet welds are much greater than 1/2" throat so PWHT would be required. The Contractor is proposing to use a 'donut' heating pad around the lug/pad.
Is this acceptable? How can this conform to the ASME Section I, Paragraph UG-40 where local PWHT must be done with a circumferential band all around the shell? How could they possibly do a circumferential band around the header shell when the bottom half of the header is all tube stub attachments?
Wouldn't it be better to use a high preheat and a temper-bead welding technique?
