PuffJr
- Jun 13, 2007
- 27
I have been asked to investigate the use of pump suction heaters for viscosity control of lube oils. Initial web searches have turned up a couple possible sources for these heaters, but I have not located good general application information for them. Are there particular temperature and/or flow rate ranges for which suction heaters are appropriate? Is it helpful to insulate a tank in which a suction heater is used?
Any experience or guidance would be greatly appreciated.
