Superfly257
Industrial
- Nov 18, 2010
- 11
Hello all,
I am very new to this and I am trying to wrap my head around what it is that pumps can and can't do, as well as what exactly all the information listed in pump brochures means.
For instance, I am looking at a pump here:
on page 18 ( the iron external gear pump)for a certain application. I need to purchase a pump that can pump 15W40 engine oil in a temperature range from -25 C (where it has a viscosity of 7000 cP)up to 200 C. The flow rates I need to hit are 0.5 to 5 GPM and I need a pressure of about 60 PSI.
I see that these pumps can get up to 1,000,000 cSt... does that mean they can pump any oil up to 1,000,000 cSt?
Also, looking on the right at, say, pump SG-0519 it looks like it can pump at my desired flow rates, but would it be able to pump an oil at 1,000,000 cSt at those flow rates?
In other words, can it pump minimum and maximum listed flow rates (and everything in between) for the entire viscosity range it has listed (1 to 1,000,000 cSt)?
Also, if I get a device to control and regulate the flow and pressure of the pump, will I be able to pump any given flow rate at any pressure, or does the pump need a specific pressure to hit a specific flow rate?
(i.e. can I pump 5 GPM at 40 psi, 60 psi, 100 psi, etc.?)
Again, I am very new to all this, and how all these things correlate to one another and work together is proving tough to understand, so any light you could shed on the situation would be greatly appreciated!
Thanks!
Thanks!
