BButler505
I have a situation where I'm using a wide flange beam as a shear collector for a diaphragm. The beam is parallel to meets a 10" CMU shear wall and I'm going to use the top bond beam to drag the shear into the shear wall. I'm going to weld a plate to the end of the wide flange with 2 headed studs and embed them in the face of the bond beam. My question is how should I calculate the tension pullout strength of the headed studs in the CMU bond beam? I was going to use the ACI 318 equations for concrete breakout strength of an anchor in tension but h.ef is larger than the CMU bond beam.
