Per API-RP-520 Part 2 section 4.2.2
"When a pressure-relief valve is installed on a line directly
connected to a vessel, the total non-recoverable pressure loss
between the protected equipment and the pressure-relief
valve should not exceed 3 percent of the set pressure of the
valve except as permitted in 4.2.3 for pilot-operated pressure relief
valves. When a pressure-relief valve is installed on a
process line, the 3 percent limit should be applied to the sum
of the loss in the normally non-flowing pressure-relief valve
inlet pipe and the incremental pressure loss in the process line
caused by the flow through the pressure-relief valve."
Does this help?
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
