I'm not convinced Mbrooke..
Decades ago I was working on power line communications. The signals had a hard time reaching very far down power lines even with clever modulation schemes. The high frequencies in arcs radiate thru the air well but not down wires very far being attenuated rapidly with distance starting with the higher frequency components.
A $5 signal processor could easily analyze an arc signal for amplitude, duration, AND distance from the processor's sensing location. So, while some loads could look like arcs they would be at excessive distances, more than a hundred feet. Local switching arcing is easily ignored simply by duration. Arcs shorter than (for example) 5 seconds could be ignored.
A power spectrum taken and applied to a characterized power line could tell you within tens of feet how far away the arc is. I suspect there would be reflections of the arc signal as the signal confronts everything from line bends, breaker housings, insulators, and transmission towers. Sifted these would show large variations in power- spectrums providing much finer distance discrimination (feet).
Basic trip settings on a unit would be:
1) Arc distance from the detector
2) Arc duration
It would log all arcs recording their finger prints.
I'd keep all events in a database to refine tripping details.
The fact that crshears bedroom AFCBs tripped on a utility arc is caused by the total focus on how little, and how cheap, they can make consumer junk.
Keith Cress
kcress -
