V
Vivek B
Guest
I need to make a grip on a handle following the handle curvilinear profile.So, I need a curve projected onto a surface and I used Style for this and got it fine....the prob now is that , coming out from style the projected circle is split into two which I found out when trying to select itand so I am not able tooffset it as a whole. The offset in the Edit menu is inactive...see the pic...If u give it a try u can understand better...If there is any other method please do share...
2009-06-12_064955_proj_curve_style.zip
Any help on this regard would be much appreciated...
