G3 surface condition for a nose cone - help
  • Thread starter Thread starter 78finn
  • Start date Start date
7
78finn
Guest
Hi there,
I am trying to model a nose cone/end surface with G3 surface conditions (as shown in the image below/ZIP file of model attached). I am using PTC Creo 7.0.
I have sketched a number of reference lines to control the length/width/depth of my surfaces, as well as adding ribbon surfaces. All of the spines in style have G3 end conditions (including the internal influencing spline). I am seeing the error reference a lot:
"The cross curves are not connected with the same continuity as the connection"
I am not sure what this error message is referring to or how I should be modelling this feature to achieve a G3 surface? If you can help me out, I would really appreciate it!
Attached is the equivalent G2 nose cone. So simple...I'm not sure why the G3 version is so much more difficult to achieve?
