Problem with hole table
  • Thread starter Thread starter Cadmus
  • Start date Start date
C
Cadmus
Guest
After creating a base plate with a series of holes, then I patterned these holes to complete the base plate. I created my drawing using the hole table-no problems so far. I then discovered that I needed some of the holes to be blind instead of through holes - hole table updated correctly. Then I changed the holes back to through holes - table will not update, still reads these pattered holes as blind. Also the hole note still sees them as blind. Any suggestions would be really helpful.
I hope by performing a Tools> Rebuild All > Save within the model will update the Hole table.
