I believe the “Kshape”, or minor loss coefficient (K or Ks), can be found e.g. for 90 degree ells/bends with various R/D and e/D ratios using Fig. #28 from “Handbook of Applied Hydraulics”; Davis & Sorenson, 3rd Ed. Pg 2-24. I also think these ell/90 values so determined could be multiplied by a correction factor C45 as per Fig. 10.6 of “Fundamentals of Pipe Flow”, by Robert Benedict, pg 371 to find a corresponding value for 45 degree bends. From a purist theoretical standpoint, there will also be additional minor losses at each pipe-to fitting end connections, when there is any difference in the inside diameter of the bend fitting relative to the entry and exiting pipe inside diameters as well (i.e. the expansion and contraction effect at any varying inside diameter “step”).
From a practical point of view, at least with regard to contemporary ductile iron pipe and fittings for water and sewer applications, there is normally very little if not insignificant minor head loss with contemporary bend fittings, at even say a 90 degree ell location, with all this being considered. In testing some time ago at the flow facility at Utah State University, a 24” (~600mm) 90 degree ANSI/AWWA C153/A21.53 (“compact” design) latest configuration ell fitting/pipe assembly with standard cement mortar lining manufactured by ACIPCO was found to have an overall (including expansion and contraction pipe end connection effects) effective minor loss coefficient value slightly less than 0.7. I believe this value, that equates to a headloss of less a tenth of a psi at a flow velocity of 3 ft/sec (~1 m/sec) based on the relationship HL=KsV^2/(2G), may be compared to the following traditional references for prior ell minor head loss coefficients:
1. K Factor .90 Reference “Civil Engineering Reference Manual”, 7th Ed., Michael Lindbergh, Professional Publications, pg 17-12, Table 17.4
2. K Factor .9 Reference “Fluid Mechanics”, 7th Ed., Wylie & Streeter, McGraw Hill. Pg 245, Table 5.3
3. K Factor .9 Reference Water Resources and Environmental Engineering, 3rd Ed., Linsley & Franzini, Mc-Graw Hill, pg. 282, Table 11-2e
4. K Factor .75 Reference Manual of British Water Supply Practice, Institution of Water Engineers, Heffer & Sons Ltd., pg. 147, Table XXVII
