Pressure balanced axial bellows
KevinNZ
NZ
Hi all
Which of these is the correct arrangement of tie rods for a pressure balanced axial bellows?
The first one does not look right and middle has too many locking nuts?
They are both just set up that way for transportation.
You will need to loosen off the bolts in the middle or the joint won't move axially to compress.
I was puzzled. The intent of a bellows is to allow moment. I worked with lox fuel lines on the atlas centaur. And the reason for the bellows was to have slight movement from vibration, Prevent failure from cracking the joints.
So I was confused why the bolts.
Little inch cleared that up.
Third one (in red) is correct. The net force in piping from EXJ is close to 0 as the forces in higher diameter annular area balances the hydrostatic force in smaller area which is connected to piping.
But as @LittleInch said, the fixing arrangements shown appears to be temporary
