earthwalker
Chemical
I would like to inquire if a voltage regulator maybe used as a power supply to a system. I am not very familiar with EE stuffs so any help would be appreciated
Our system consists of aluminum metal plates submerged in water. It needs to be supplied with 10A (DC) thru the portion of the plate that is not submerged.
What I have is a voltage regulator with variable output. Its input is 220V and output maybe adjusted thru a knob from 0-250V and with maximum capacity of 12A.
My question is that will it suffice to serve as our power supply? Would the output be DC or AC? And am I right to say that what we are supposed to do is to adjust the voltage output until the current read is 10A? Thanks in advance.
