This is a new one on me. Someone called wanting my help on figuring out why they have had 3 failures of Line Reactors ahead of some 40HP VFDs. 30 years in this industry and I have never once seen a line reactor fail. It's too stupid of a device; wire and iron. What could fail? So far no details, I have a meeting in 2 days in which the customer will give me part numbers and mfrs of the components in the system. Until then, I'm just trying to ferret out possible directions to go with this so that I can sound reasonably intelligent when I talk to them.
So in looking around, I notice that all of the big names in reactor suppliers all say their reactors are "harmonic compensated". I've seen that forever, always just took it at face value. But does that imply then that there is such a thing as a "non-harmonic compensated" reactor? My thoughts are that possibly whomever built this system found some el-cheapo reactor supplier and they are not up to the task, i.e. not "harmonic compensated" somehow. One thing that leads me to that already is that in the sketchy info I have so far, they said they are "2% reactors", and nobody I know of offers 2%, they are either 3% or 5%. So my thought is that if they somehow found a cheap source, it may be that the reactors were not intended for use as line reactors for VFDs, i.e. not harmonic compensated.
Any other ideas? Are there some bizarre interactions with something else, similar to capacitor resonance, that could be causing the reactors to fail? Anyone else see reactor failures?
And yes, my first line of reasoning, until I get numbers and data, is that someone simply picked reactors that are too small. That just seems too obvious though. Considering they have replaced them twice now, one would think that they would have checked that first. Still, I've seen people do things like that...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
