Positioning Irregular Shaped Feature
JLang17
90
I have an irregular shaped hole that is basically located and sized with tolerances (similar to the shape of this "0" if the left and right sides were flattened). I want to say it can be positioned with a dia. tolerance of .001 at MMC, but my book says I can only apply a positonal tolerance with cylinder, width or spherical features. A profile tolerance doesn't make sense because as the hole departs from MMC, it would break the tolerance zone.
I think I could use a positional tolerance attached to the height and one attached to the width, both with the note "BOUNDARY", but if they're the same tolerance it seems there's a better way.
Any help?
Meant to say, in that case your FCF would be .011 top line .005 bottom line, I'd confused myself.
KENAT,
Have you reminded yourself of faq731-376 recently, or taken a look at posting policies:
OK KENAT, you can have it all, I'm pretty much through concentrating today anyway ;-)
"Good to know you got shoes to wear when you find the floor." - [small]Robert Hunter[/small]
"JLang17 (Electrical) 12 Feb 09 11:52
Let's say I want to use a profile control for the feature in my original post, and the size tolerances are +-.005. I want to confine the location to a diameter of .001, and allow size to adjust within a zone of .01. How do I show this?
It was meant to be corrcting my reply to the above but was still wrong.
The .001 positional doesn't make much sense but I think the OP would want FCF with .006 in the top and .005 in the bottom, but I've lost all faith in myself now.
KENAT,
I figured you meant .006 in the top instead of .011, so it's all good. Thanks for the help.
