can a feature's position tolerance having itself as a datum?
i like to control the hole location real tight ref to main axis and end plane, but it could be loose relative to flange orientation.
if the part axis A, end surface B, the hole in concern C, the position tol of the hole "POS dia .002 S A B C".
or i must generate the line connecting two flange holes as D, then specify "POS dia .002 S A B D"?
thanks.
thanks.
