Portable high pressure pump
Koh
SG
I'm looking for a water pump with the following specifications
- about 20 kg
- can deliver as high as 100 bar pressure. (at least 15 bar)
- flow rate larger than 13L/min. (The higher the better)
- portable (battery operated or diesel/gasoline operated)
Hope that someone can help. Thanks.
YM
try a piston/plunger pump from the likes of CAT or Interpump or a PD pump like the Wanner Hydracell
sounds like an off the shelf jetting/jet wash/pressure wash package. Sounds silly but if you are looking for portability, try your local hardware store, most will be electric so couple it with a portable generator
