johnnydO3
Industrial
- Mar 1, 2007
- 2
I am looking for possible causes for above water level corrosion at a few indoor pools. Some are using bromine and others chlorine, but all are on ozone and chemical automation. The bromine pools have contact columns and the chlorine pools have large contact tanks all with off-gassing and destruct. 5 of the pools are in one city with the same equipment in each but only 2 of the 5 have corrosion. The rusting is forming on the stainless gutters and hand rails on the ladders, but again only above the water level in the pool area. There is however corrosion in the mechanical room also of the pools with the problems. In the mechanical rooms with rusting they do have a balance tank in each. Any ideas?
