Point cloud data
  • Thread starter Thread starter satish153
  • Start date Start date
S
satish153
Guest
Hi all,
How to use point cloud data for making the model (may be surface)
satish
i have never used this feature but it works in following way
click on offset coordinate system datum point tool
select the coordinate system from the model tree (or screen)
then click on import.
you can import your point cloud data file in two formats.
.pts
.ibl.
so you have to change your file extention accodingly.
please let me know if it works
or if possible can u send me the point cloud file you have. so that i can give it a try.
my e-mail adress is kar.sanjeev@gmail.com
Edited by: sanjeevkar1
Whats d significance of point cloud data?
Whats dat extensions .pts and .ibl?
Whats d data to store as .pts and .ibl extensions?
Hi Sanjeev,
To be more specific I have an IGES file which contains the points. Iproceeded as per your guidence but my pro-e crashes every time I tried. The size of the IGES file is 23.2mb
We have some hint in the Pro-E help in surfacing>>Pro/scan but could not get the benifite
Importing points as coordinate points probably wasn't meant for point clouds (23.2 MB worth of points seems a lot
Point clouds are the typical output of 3D-scanners. Demonstrations I've seen all had postprocessing software that were able to translate the poionts into a surface that in its turn could be exported as IGES for instance.
Alex
satish
can you send me the file please
