K
kathy
Guest
Dear Gurus:
I am stuck in simulation constraints. I have a simple cylinder. I fix all 6 dof on top surface, then I apply a load around cylinder, then I put constraint 2 on the bottom surface. I want the bottom surface rotate around X axies, here is how I set the constraint 2: Translation: X=Y=Z=0; rotational: X=1.5 radian, Y=Z=0.
Then my simulation resultis wrong! The bottom surface won't rotate around X axis to 1.5 radians. Can anybody tell me what is wrong with the constraint?
Thanks a lot!
Kathy
Thanks a lot!
Kathy
