Folks,
This is a theory question rather than an actual problem.
Some background - The company I work for has an old design guide for design of air ducting. The formula for plate stress under uniform loading is given as: fb = (K1 Q X^2)/t^2
Where fb is plate stress, K1 is a factor relating to the aspect ratio of the plate, Q is the pressure on the plate, X is the distance between stiffeners and t is the plate thickness.
The formula is supposed to be a rough avarage of the stresses generated by fixed and simply supported conditions.
Now. I thought I'd check this by camparison to Pounder's Theory, which gives formulas to calculate stress for fixed and simply supported conditions. It turns out that the stresses given by my companies formula are LOWER than those given by Pounder's theory. Ho hum - good job I've not relied on it!
I then thought I'd do a further comparison by using finite elements. I modelled a number of plates with both fixed and simple supports and with varying aspect ratios. This produced two nice curves of lower stress than either Pounder's theory or my company formula - Just as I'd hoped/expected. BUT closer examination of the curves shows that the simply supported plate has lower stresses than the fixed plate. This is not what I would have expected or what Pounder's theory predicts.
Now for the question(s): Is my F.E analysis wrong? Has anyone else done this type of simple modelling? The models are metric models using the follwing plate sizes (in mm) 1000x200, 1000x400, 1000x600, 1000x800, 1000x1000, 1000x1200, 1000x1400, 1000x1600, 1000x1800 and 1000x2000.
I've applied a uniform load and set the plate at 5mm thick steel.
I need to investigate this myself over the Christmas / New Year period but I'd appreciate any comments people may have.
I'm guessing it's a simple modelling error but can't see it right now.
Everyone - Have a good Christmas...
