stressebookllc
Aerospace
Dear Friends, I am in the process of double checking a simply supported 10" x 4" plate, supported at the 1.0" from the short edges. The edges are only constrained along TZ. A weak spring is used right in the middle to avoid any fatal errors. Then I used three different mesh sizes to look at the convergence of the normal stress. I have attached the model.
The plate is 0.25" thick and the applied load is 1000lb along -Z.
When we do a simple bending stress calc, Sigma = Mc/I, we get 48ksi.
In the model however (looking at the shell normal-X bottom output vector), it is close but higher than theory for the fine mesh, and the coarser mesh is closer to theory.
So I was wondering what you guys think about this. The goal is to use mesh convergence and hopefully get closer to the theoretical Mc/I at the middle of this plate.
Stressing Stresslessly!
