boffintech
The specs under section 3300 Cast-in-place concrete under High Range Water Reducers reads in part:
“Do not permit fresh concrete containing superplasticizers to come in contact with fresh concrete not containing superplasticizers.”
Case in point. On the job there is a foundation wall that requires 4000 psi (3”-5” slump) concrete that has several pilasters (columns integral with the wall) that require 7000 psi (6”-8” slump) concrete. The 7000 psi mix has high range water reducer to achieve the 6” to 8” slump.
The columns in questions were poured simultaneously with the wall by alternating 7000 in the column and then 4000 on each side so that the 7000 was “trapped” in the column. Clearly this method of concrete placement is disallowed by the specs. I admit that at the time I had not fully considered the point and now wish to fully cogitate upon it.
What are the consequences of this placement method? Why is this placement method disallowed by the specs?
