We have been using 2" lengths of 2" XS SA106 GrB pipe in pairs to hold a tapped bar. One difficult application cycled this loaded pair of pipes nearly 200000 times and failed. The pipes are welded on one tangent (top and bottom). The failure has been attributed to crack initiation and propigaton at multiple microscopic pits, along the loading line.
We received the cut pipe by the several hundreds, they look fine and are relatively rust free. This is after all, pipe. So, the 2" sections are cut from 20, 40 ft lengths that could be sitting out of doors.
Is it reasonable to expect the pitting? Is seamless process the culprit? Is there a process to ask for or to ensure is not done that would eliminate the pits?
Thanks for your input
Dave Harhay
Sypris Technologies
Tube Turns Products
Dave Harhay
Sypris Technologies
Tube Turns Products
