I see lots of callouts where thread pitch diameter and gear pitch diameter are the primary datums.
I had an instance recently where an outlet hole in an oil jet had to be controlled back to a thread pitch diameter as its primary datum.
As a pitch diameter is a theortical diameter I'm having a hard time undertsanding how you would (in pratical terms) inspect back to that pitch diameter? How would the inspection fixture be set up for a primary datum on an external thread pitch diameter, a NO-GO threaded hole in the fixture to hold the threaded part?
As I encounter this situation a lot and I need to understand the inspection method more so I can really understand what the tolerances will be that are specified back to a pitch diameter primary datum.
Airfix
Airfix
