PIPING ITEM
Ramil Abbaszade
FR
Good day dear Engineers/designers.
Does anyone know what is the name of this welded item? It is very unique and existing something we need to change this item. It is small bore and has got clamp to hold 2 lips together. There is also seal between two lipped faces. Photos are attached. Waiting for your thoughts!
Ramil Abbaszade
Stress Engineer
They are called tri clover or tri clamp pipe connectors. There are many suppliers and manufacturers. Are there any marks, names, numbers stamped on it?
Haha, tri clamp yes. Made to a dozen standards from a dozen countries, all of which vary a little bit (the devil is in the details). Make sure you get the right standard, like, DIN 32676, DIN, 118xx, ISO 2852, ASME BPE, etc. For future purposes, we found it's best to standardize on the ASME BPE design for tri clamp ferrules (i.e. with respecto to dimensions etc.). It's mosty commonly accepted and available.
Gentlemen, Thank you so much for this useful information.
Best Regards,
Ramil Abbaszade
Stress Engineer
