Hi
Refer attachment.
As per ASME Y14.5:2018
Design requirement:
1) Datum A will contact with mating part.
2) Two holes are used to locate and mount the part.
3) Outer surface (15) should be equally disposed from center plan of two holes (datum B).
4) Dia 8.5 holes axes coincide with center plan of two holes (datum B) and located from datum A.
If pattern of holes are datum B, how to position the pitch dimension.
In the drawing, 6 in vertical, 4 and 6 in horizontal which are locating the 2X Dia 3.3 holes. Should I make those dimension basic?
Anything to modify in drawing.
Thank you.
Refer attachment.
Design requirement:
Thank you.
