Lubocjw
Geotechnical
- Dec 22, 2005
- 2
Hi,everybody!
In recent studies ,I found that mechanica-hydraulic coupling problems are hard to converge ,especially with the partial saturation seepage considered at the same time.In the first analysis step ,when the gravity is loaded ,the solution seems to be divergent ,and the procedure will terminate.Not to mention the engineering loads to be applied.I don't know if there are some techniques to better the convergence and make the solution complete.
Any constructive advice or discussion will be appreciated!
Thank you!
Thank you!
