Hi all - see attached simplified model.
I have a plate with some clearance holes used for mounting. The datum reference frame will be A|B where A is two partial areas as detailed. Datum feature B will be the pattern of 2X holes and all other features that I redacted from this model will be profile to A|B(M). The edges of the plate mean nothing to me so I am opting to not do a 3-2-1 style set up.
My question is regarding the two partial areas. I understand that the partial area size is basic but how would I locate the partial areas given my set up above? I assume there should be a basic location between the two partial areas (is that correct?) but then what sets the initial location of the partial areas?
Thanks for the help
Thanks for the help
