Part Cleanup 1
holyghost
Aerospace
Feb 13, 2010
77
Does Part Cleanup will work effectively ? When we do part cleanup all unwanted / unused sketches , curves Sheets etc should delete right. But I tried on a solid blok I draw sketches and curves (not used any where) but those are not deleting when I do part cleanup.
any suggestions?
I don't think Part cleanup does deletetion of that sort you are looking for.It is supposed to be more of a refinement tool rather than deletion (i do agree it may delete some extraneous objects but not the entities as a whole).
The best way to get rid of unused entities will be to TURN OFF the Timestamp Order (right click in PART NAVIGATOR) and then you will find all the unused objects under UNUSED ITEMS node.You can then delete these.
Best Regards
Kapil
