How can I calculate my pumps performance in parallel conditions?
In our LPG system we have two pumps (motor/turbine), usually motor pump is running most of the time. The common discharge line will split into tow streams one to rundown (LPG to storage) and the other one back to the column as a reflux.
Based on filed survey, it was noticed that running with a Turbine pump will not delivered the required head, on other word it is not equivalent to the motor pump. More money needs to be spent to upgrade the turbine pump.
We are planning to increase our unit throughput and based on the Engineering study it was found that another motor pump is required to run in parallel to the existing motor pump. Therefore, we are going to run with two motor pumps in parallel in the future.
The question is, how can I ensure that running with a motor and turbine pump in parallel will deliver the required flow for the future case?
We are thinking to carry out a test run now to run both turbine and motor pump is parallel to have a good base line.
What other things that I need to be considered during my testing? Your help in this matter is required. Thank you.
