I do not really understand the question. Why should there be any hesitation at all? A relay coil usually doesn't consume much current. And even if there are two in parallel, it doesn't mean much current.
A 33 ft cable (about ten metres) is not a long cable, so the voltage drop will be neglible - unless you are using a very thin cable. Anything which is thick enough to constitute a "cable" can be used.
I'm sorry the question was unclear.
The person that told me to use 3 wire cable started my confustion - I see the need for only 2 wire cable.
That was my qestion.
