Hi all,
Please advise on the following. for all reference this is in accordance with B31.3 2012
I have a furnace tube of material specification P5B
The user needs to attach a thermocouple via fillet weld of 3mm to the outside of the tube of which the material is a P8 stainless steel.
The table 331.1.1 says that all weld sizes are mandatory under P5B material specification but in paragraph 331.1.3 (2) says that for P-No 3,4,5 & 10A when weld throat thickness is less than 13mm PWHT is not mandatory as long as the minimum preheat is applied. Please advise if i am reading this correctly and if it applies to P5B material.
Kind regards
Ruben Naidoo
Senior Inspector of Pressure Equipment
SAPREF Refinery SA (SHELL & BP)
Kind regards
Ruben Naidoo
