Oxygen Piping
robinxie
Chemical
Nov 13, 2001
52
Does anyone know the standard (ASME B31.3?) for oxygen pipe, or piping specification (material, prssure rate, temperature, installation, inspection)? Where could I find that stuff?
Thanks in advance.
Robin
With pure oxygen i know that you should be carefull with your piperouting. A sharp bend shhotly afer valve could create a situation where the pzygen "burns" through the pipe very fast.
Best Regards
Morten
Robin - Look in the "Piping Handbook" under cryogenic systems. Another good reference is "Materials Selection for the Chemical Process Industries".
MOST operators use austenitic stainless for LO2 systems.
This information is provided for your entertainment only! Thanks!
Pete
Thank you very much, guys. Dose you guys know how to size this pipe?
Robin
