rkbengineer
I have a project going in where the contractor is placing onsite fill material for a permanent quarry haul road. Unfortunately the contract and specifications do not limit the particle size (usually taken as about 3"). The material is generally very good, but has quite a few cobbles in it. Their sizes range from 3" up to 12" and are visually estimated at 25% to 30% of the total sample. The material gradation was only performed on the material passing the 3" sieve and shows 32% to 44% retained on the 3/4".
I am trying to use the ASTM documents referenced in the specs to enforce a maximum particle size of 3" to 4". ASTM D2922 and D1557 both refer to D4718 for oversize particle correction. D4718 puts the ...upper limit of oversize particles at 30% of the plus 3/4" material.
My question is whether there is an upper limit on particle size in addition to the percentage. I need something that I can use contractually to enforce this. This will be clarified in the next phase of work. Any help will be greatly appreciated.
