option for adding Geo Tol
cam721
26
What is the setting or option that you need to apply in order to add Geometric Tolerances to a created dimension (as opposed to a shown dimension).
Wildfire 2.0
Thanks!
-Art
Check your Help:
Configuration File Options for Drawing Mode
The following configuration file options are specific to Drawing mode functions. See Configuration File Options in Pro/HELP for full information about these options and for a complete list of configuration file options available for Pro/ENGINEER.
allow_move_view_with_move
allow_mod_attach_draft_dim
allow_move_attach_in_dtl_move
auto_associative_dimensions
auto_regen_views
create_drawing_dims_only
default_draw_scale
dim_fraction_format
display_dwg_tol_tags
display_in_adding_view
disp_trimetric_dwg_mode_view
draw_models_read_only
draw_points_in_model_units
drawing_file_editor
drawing_setup_file
drawing_view_origin_csys
dwg_select_across_pick_box
force_wireframe_in_drawings
format_setup_file
highlight_erased_dwg_views
highlight_new_dims
make_parameters_from_fmt_tables
make_proj_view_notes
pro_dtl_setup_dir
pro_format_dir
rename_drawings_with_object
save_drawing_picture_file
save_modified_draw_models_only
selection_of_removed_entities
switch_dims_for_notes
sym_leader_orient_move_text
todays_date_note_format
variant_drawing_item_sizes
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Some other items from the Help Files
Placement—Places the geometric tolerance in the drawing. Click Place geometric tolerance and select an item from the Type list:
Dimension—Attaches the geometric tolerance to a dimension. The drawing setup file option gtol_dim_placement determines its location below the dimension. You can attach multiple gtols (stacked) to the same dimension, and they behave as a single tolerance when you manipulate the dimension symbol.
Datum—Attaches the geometric tolerance to a datum. If the geometric tolerance is already attached directly to a datum, the system selects this item for you.
Leaders—Attaches the geometric tolerance to multiple edges (including datum quilt edges) with leader lines or to dimension witness lines.
Free Note—Places the geometric tolerance anywhere on the drawing. In Part mode, you cannot display free gtols that were created in Drawing mode. You can use Free Note placement only when you have selected The Drawing from the Model list as the top model.
Normal Leader—Attaches the geometric tolerance to an edge along a leader line that is perpendicular to the selected edge.
Tangent Leader—Attaches the geometric tolerance to an edge along a leader line that is tangent to the selected edge, orienting the geometric tolerance text box at the same angle as the leader.
Other Gtol—Attaches the new geometric tolerance to an existing one (you cannot attach the existing geometric tolerance to a dimension).
Dim Related—Relates a geometric tolerance to specified dimension text. Select this item from the Type list; then select dimension text and a location relative to the text. To relate an existing free geometric tolerance to dimension text, choose TOOLS > Relate Obj.
Make Dim—Creates a driven dimension and attaches the dimension to it. This dimension belongs to the drawing. The geometric tolerance appears in standard dimension format, but with the geometric tolerance instead of a dimension value.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
