Hello everyone.
First post here. I came looking for some help, if possible!
I have to help in the design of a shallow foundation for an oil storage tank. Previous projects of the company where I am doing this were executed with ring foundations and, well, it would be helpful if we could use the same solution once again.
Simplified stratigraphy of the soil is as follows:
First layer: 0-3 meters, sand;
Second layer: 3-20 m, clay;
Third layer: 20-35 m, sand.
GWT: 1 - 2 meter depth.
Tank has 10 meters radius, 11 meters height.
Assuming that the shallow foundation will rest in the superficial sand layer, I would like to have some guidance in the following questions:
1) As happens in the first sand layer (drained loading), the second (clay, undrained loading) and third layers (sand, drained loading) will also experience immediate settlements due to tank loading? How can I calculate them? I guess I can use something like Boussinesq Pressure Bulbs to understand the depth of influence of tank loading. The final immediate settlement is the sum of the partial immediate settlements, calculated for each layer?
2) The clay layer has a large thickness. What is the best methodology for calculating consolidation settlements? 1D theory like thin clay layers with no horizontal movements? Or a three-dimensional consolidation theory?
3) In respect to bearing capacity, should I only concern about the superficial sand layer, where the foundation will stand? Shouldn't I check bearing capacity for the clay layer, especially due to undrained loading)? But won't its bearing capacity be much smaller than the sand one, over designing the project?
4) The ring foundations usually executed have, for example, a section of 1,30 meter (height) x 0,70m (width). The center is filled with a correctly chosen granular material, I guess.
My question is, with this kind of solution, there aren't something like "two levels" of foundations? One is the bottom plate of the tank (where centered settlements will happen) and the other is the concrete ring itself, where also settlements will happen under it, no? Is this idea "correct" or "valid"? How can I simplify it for analytical calculation and then compare it to modeling (PLAXIS)?
Thanks in advance!
Thanks in advance!
