Offshore Gas Compression Energy usage
kjm20
Chemical
GB
I have been asked to carry out an energy assessment of an offshore platform in the southern north sea.
Although I have looked everywhere I can’t seem to find the industry standard for a compression plant of the following value; the amount of energy used in transporting and processing the reservoir fluids over the energy value of the exported product (%).
Can anyone point me in the right direction to finding this answer or happen to know it off the top of their heads??
Thank you for you help!
That is probably because until recently the operators didn't care much about energy usage... just as long as there was gas/oil flowing through the pipeline...
I suspect that the energy value of the transported product is vastly greater than the energy usage in transporting and processing, so the ratio may not be very meaningful..
But I might be suprised, I certainly have been before...
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
We use 1.5% per stage. A stage being 3 ratios.
I think BP use 2% as their base point for new developments. Bound to be something about it on their website.
It's a massive amount of energy when you think about it!
