Over the last summer, I was sitting in the window seat of a Boeing 737, on the right side, just in front of the wing root, directly inline with the inlet of the turbofan. It was raining and there was quite a bit of water standing on the tarmac.
After pushback, the engines spooled up. I watched the vortices generated by the rapidly inrushing air turn into a “Snake” of water and air, pulling forward from the engine about 3 meters, then turning 90 degrees downward to the ground. The snake was about 30 inches in diameter and as long as the engines were at taxiing speed, the snake was consistent, becoming more visible as we taxied through water puddles.
When we reached the runway, the engines spooled to takeoff power and the snake stretched out almost out of sight of the window, but still staying attached to the ground.
As we approached takeoff speed, the snake disappeared but it stayed visible to just before rotate velocity.
In all of my flights over 40 years, I have never seen such a sight. I never realized the drop in air pressure would vaporize the water so visibly. Opinions?
