Hi. When using edit object display in NX 9, I can't get the colors to adhere to the component while out in the assembly context.
If I'm in an assembly and hit edit display, I select the object (component) and choose a color. "Apply to all selected faces" and "apply changes to owning part" are greyed out under settings in the dialog. I select a new color and it is fine in the assembly I'm in, but when made the displayed part, the color is the same as original. Also, out in the assembly if I check the properties of the component I tried to change, the "specific component color" box is checked. I did check those boxes in customer defaults.
Did something change here? I need to be able to select multiple components and change their colors so that the colors change in the part itself too.
