NX4: ERROR: ...not in relevant class.
tooldeziner
Aerospace
Oct 14, 2005
98
Hello all,
Working with assembly files, when I save this error appears:
The following parts failed to save causing the overall save operation to fail:
While saving "file name":
"file name"- Internal error: an attempt was made to access an attribute not in the relevant class.
At first I thought it was because some of the parts in the assembly belong to other people, but then I saw the same error with an assembly file containing only 2 components: both mine.
With both components closed, the top file would save. But, with either one or both of the components loaded, the error appeared. Bear in mind, this is an intermittent error. Although it occurs frequently, it is unpredictable.
Does anyone else get this?
Thanks,
'ziner
Peace Through Superior Fire-Power!
Although this is actually a question that should be posed to GTAC, not this forum, I will state that, yes, we encounter that error quite often. Without getting too in depth, I am going to make the assumption you are running in TC Engineering, and not Native. The problem lies in that black tunnel that links NX to TC...
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
There was just a discussion about a problem that sounds very similar to this on the UGS BBS and it appears that this will be fixed with the release of UGS NX 4.0.4.2 MP1 (which should be available before the end of June). In the mean time, you may be able to reduce the incidance of experiencing this problem if you change your Load Options to 'Use Partial Loading: ON'.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
Are you promising a specific release date, John? Hmmm...
-Derek
