Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module delete_ID_symbols
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.Work) Then
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "Delete ID symbols: triangle up"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        If workPart.Annotations.IdSymbols.ToArray.Length = 0 Then
            lw.WriteLine("No ID symbols found in current work part")
            Return
        End If
        Dim triangleUp As New List(Of Annotations.IdSymbol)
        'loop through all the ID symbols in the part
        For Each tempID As Annotations.IdSymbol In workPart.Annotations.IdSymbols
            Dim oldIdBuilder As Annotations.IdSymbolBuilder
            oldIdBuilder = workPart.Annotations.IdSymbols.CreateIdSymbolBuilder(tempID)
            'type of symbol to change
            If oldIdBuilder.Type = Annotations.IdSymbolBuilder.SymbolTypes.TriangleUp Then
                triangleUp.Add(tempID)
            End If
            oldIdBuilder.Destroy()
        Next
        Try
            theSession.UpdateManager.ClearErrorList()
            Dim markId2 As Session.UndoMarkId
            markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Delete ID symbols")
            Dim nErrs1 As Integer
            nErrs1 = theSession.UpdateManager.AddToDeleteList(triangleUp.ToArray)
            Dim nErrs2 As Integer
            nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
        Catch ex As NXException
            theSession.UndoToMark(markId1, undoMarkName)
            MsgBox(ex.Message)
        End Try
        lw.Close()
    End Sub
End Module
