GiantIsopod
- Jun 24, 2025
- 5
How can I get expressions into excel? I can get them into an NX display window using the code I attached, but I run into problems using VB to make this an excel file. Even if I can just get the names into Excel in a column that'd be great. Any help is greatly appreciated.
Option Strict Off
Imports System
Imports NXOpen
Module NXJ_Exp_1
Sub Main()
Dim theSession As Session = Session.GetSession()
If IsNothing(theSession.Parts.Work) Then
'active part required
Return
End If
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Const undoMarkName As String = "NXJ query expressions"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
For Each temp As Expression In workPart.Expressions
lw.WriteLine("name: " & temp.Name)
lw.WriteLine("type: " & temp.Type)
lw.WriteLine("description: " & temp.Description)
lw.WriteLine("descriptor: " & temp.GetDescriptor)
lw.WriteLine("journal identifier: " & temp.JournalIdentifier)
lw.WriteLine("measurement expression? " & temp.IsMeasurementExpression.ToString)
lw.WriteLine("geometric expression? " & temp.IsGeometricExpression.ToString)
lw.WriteLine("edit locked? " & temp.IsNoEdit.ToString)
lw.WriteLine("locked by user? " & temp.IsUserLocked.ToString)
lw.WriteLine("right hand side: " & temp.RightHandSide)
lw.WriteLine("equation: " & temp.Equation)
If temp.RightHandSide.Contains("//") Then
'expression contains comment
Dim expComment As String = ""
expComment = temp.RightHandSide.Substring(temp.RightHandSide.IndexOf("//") + 2)
lw.WriteLine("comment: " & expComment)
End If
Select Case temp.Type
Case Is = "Number"
lw.WriteLine("value (base part units): " & temp.Value.ToString)
Try
lw.WriteLine("expression units: " & temp.Units.Name & " (" & temp.Units.Abbreviation & ")")
lw.WriteLine("value in expression units: " & temp.GetValueUsingUnits(Expression.UnitsOption.Expression).ToString)
Catch ex As NullReferenceException
lw.WriteLine("expression is constant (unitless)")
Catch ex2 As Exception
lw.WriteLine("!! error: " & ex2.Message)
End Try
Case Is = "String"
lw.WriteLine("string value: " & temp.StringValue)
Case Is = "Integer"
lw.WriteLine("integer value: " & temp.IntegerValue.ToString)
Case Is = "Boolean"
lw.WriteLine("boolean value: " & temp.BooleanValue.ToString)
Case Is = "Vector"
lw.WriteLine("vector value: " & temp.VectorValue.ToString)
Case Is = "Point"
lw.WriteLine("point value: " & temp.PointValue.ToString)
Case Is = "List"
'returns a generic object, not especially useful
'lw.WriteLine("list value: " & temp.GetListValue.ToString)
'parse the right hand side to get the list items
Dim theList As String = temp.RightHandSide
theList = theList.Replace("{", "")
theList = theList.Replace("}", "")
Dim theItems() As String = theList.Split(",")
For Each item As String In theItems
lw.WriteLine(item.Trim)
Next
Case Else
lw.WriteLine("Type: " & temp.Type & " is not handled by this journal")
End Select
Dim theOwningFeature As Features.Feature = temp.GetOwningFeature
If Not IsNothing(theOwningFeature) Then
lw.WriteLine("owning feature: " & theOwningFeature.GetFeatureName)
End If
Dim theOwningRpoFeature As Features.Feature = temp.GetOwningRpoFeature
If Not IsNothing(theOwningRpoFeature) Then
lw.WriteLine("owning rpo feature: " & theOwningRpoFeature.GetFeatureName)
End If
Dim referencingExps() As Expression = temp.GetReferencingExpressions
If referencingExps.Length > 0 Then
lw.WriteLine(" $$ used by expression(s):")
For Each refTemp As Expression In referencingExps
lw.WriteLine(" " & refTemp.Name)
Next
End If
Dim referencingFeats() As Features.Feature = temp.GetUsingFeatures
If referencingFeats.Length > 0 Then
lw.WriteLine(" %% used by feature(s):")
For Each featTemp As Features.Feature In referencingFeats
lw.WriteLine(" " & featTemp.GetFeatureName)
Next
End If
lw.WriteLine("")
Next
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Option Strict Off
Imports System
Imports NXOpen
Module NXJ_Exp_1
Sub Main()
Return
End If
lw.Open()
End If
Case Is = "Number"
Try
End Try
Case Is = "String"
Case Is = "Integer"
Case Is = "Boolean"
Case Is = "Vector"
Case Is = "Point"
Case Is = "List"
Next
Case Else
End Select
End If
End If
Next
End If
Next
End If
lw.WriteLine("")
Next
lw.Close()
End Sub
End Function
End Module
