Put NX Expressions into Excel
GiantIsopod
How can I get expressions into excel? I can get them into an NX display window using the code I attached, but I run into problems using VB to make this an excel file. Even if I can just get the names into Excel in a column that'd be great. Any help is greatly appreciated.
Option Strict Off
Imports System
Imports NXOpen
Module NXJ_Exp_1
Sub Main()
Dim theSession As Session = Session.GetSession()
If IsNothing(theSession.Parts.Work) Then
'active part required
Return
End If
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Const undoMarkName As String = "NXJ query expressions"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
For Each temp As Expression In workPart.Expressions
lw.WriteLine("name: " & temp.Name)
lw.WriteLine("type: " & temp.Type)
lw.WriteLine("description: " & temp.Description)
lw.WriteLine("descriptor: " & temp.GetDescriptor)
lw.WriteLine("journal identifier: " & temp.JournalIdentifier)
lw.WriteLine("measurement expression? " & temp.IsMeasurementExpression.ToString)
lw.WriteLine("geometric expression? " & temp.IsGeometricExpression.ToString)
lw.WriteLine("edit locked? " & temp.IsNoEdit.ToString)
lw.WriteLine("locked by user? " & temp.IsUserLocked.ToString)
lw.WriteLine("right hand side: " & temp.RightHandSide)
lw.WriteLine("equation: " & temp.Equation)
If temp.RightHandSide.Contains("//") Then
'expression contains comment
Dim expComment As String = ""
expComment = temp.RightHandSide.Substring(temp.RightHandSide.IndexOf("//") + 2)
lw.WriteLine("comment: " & expComment)
End If
Select Case temp.Type
Case Is = "Number"
lw.WriteLine("value (base part units): " & temp.Value.ToString)
Try
lw.WriteLine("expression units: " & temp.Units.Name & " (" & temp.Units.Abbreviation & ")")
lw.WriteLine("value in expression units: " & temp.GetValueUsingUnits(Expression.UnitsOption.Expression).ToString)
Catch ex As NullReferenceException
lw.WriteLine("expression is constant (unitless)")
Catch ex2 As Exception
lw.WriteLine("!! error: " & ex2.Message)
End Try
Case Is = "String"
lw.WriteLine("string value: " & temp.StringValue)
Case Is = "Integer"
lw.WriteLine("integer value: " & temp.IntegerValue.ToString)
Case Is = "Boolean"
lw.WriteLine("boolean value: " & temp.BooleanValue.ToString)
Case Is = "Vector"
lw.WriteLine("vector value: " & temp.VectorValue.ToString)
Case Is = "Point"
lw.WriteLine("point value: " & temp.PointValue.ToString)
Case Is = "List"
'returns a generic object, not especially useful
'lw.WriteLine("list value: " & temp.GetListValue.ToString)
'parse the right hand side to get the list items
Dim theList As String = temp.RightHandSide
theList = theList.Replace("{", "")
theList = theList.Replace("}", "")
Dim theItems() As String = theList.Split(",")
For Each item As String In theItems
lw.WriteLine(item.Trim)
Next
Case Else
lw.WriteLine("Type: " & temp.Type & " is not handled by this journal")
End Select
Dim theOwningFeature As Features.Feature = temp.GetOwningFeature
If Not IsNothing(theOwningFeature) Then
lw.WriteLine("owning feature: " & theOwningFeature.GetFeatureName)
End If
Dim theOwningRpoFeature As Features.Feature = temp.GetOwningRpoFeature
If Not IsNothing(theOwningRpoFeature) Then
lw.WriteLine("owning rpo feature: " & theOwningRpoFeature.GetFeatureName)
End If
Dim referencingExps() As Expression = temp.GetReferencingExpressions
If referencingExps.Length > 0 Then
lw.WriteLine(" $$ used by expression(s):")
For Each refTemp As Expression In referencingExps
lw.WriteLine(" " & refTemp.Name)
Next
End If
Dim referencingFeats() As Features.Feature = temp.GetUsingFeatures
If referencingFeats.Length > 0 Then
lw.WriteLine(" %% used by feature(s):")
For Each featTemp As Features.Feature In referencingFeats
lw.WriteLine(" " & featTemp.GetFeatureName)
Next
End If
lw.WriteLine("")
Next
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
You should write small functions that do the pieces of work that you want. this way the main program is calling functions to do the work
