NPSHa calculation
elowami
Chemical
LY
Hi all,
I want to ask about calculation of the net positive suction head available for ethylene pump (vertical multistage pot mounted submerged motor pump).
see the attached picture.
my question is :
the calculation of the net positive suction head available based on point 1 or point 2.
Thanks in advance for your help.
 https://files.engineering.com/getfile.aspx?folder=42ab032a-3855-4079-99ae-985f48331613&file=e.jpg
If you've bought it as a single item, most pump vendors supply NPSHR at the centre line or face (for vertical pointing flanges) of the inlet flange.
Only the vendor / vendor supplied design manual can tell you for sure.
yes I have the NPSHr from the vendor datasheet 0m at datum and 1.2m at the grade.
