Nozzle Lables
mdare35
Is there anyway to get the 3D shot on the cover sheet to have bigger labels for the nozzles? I'm thinking the balloons you typically see on assembly drawings would be nice.
COMPRESS does not provide options to change the nozzle markings. However, you can use any graphic file for the Cover Page (or you can omit the graphic image). Thus users can use a photograph, drawing, etc, as the image on the Cover Page.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
