ImSniffy
- Nov 12, 2010
- 1
I'm building an arch foot bridge over a small creek using large concrete blocks, but I've decided to reduce the elevation by using an ellipse. My question is regarding the calculation of the segment angles. In a normal arch the span is divided into sections and each block is shaped into a isosceles trapezoid. The side angles are derived by taking the 180deg arc and dividing it into the desired number of segment sections and bisecting these points through the focal point of the radius. The isosceles trapezoid causes a wedging action with its neighbor giving compressive strength...but you probably aready knew that
How do I do this with an ellipse? Where is the best height of the center point for the angles to start from for wedging to occure?
